Bosch Performance CX Sprocket
Trekkie
19
Leicestershire
I want to upgrade the front sprocket on my bike. It currently has a 15 tooth sprocket and bought a 20 tooth but it is too big as the motor casing has a moulding which I guess acts as a chain guide. Has anyone updated a Trek Powerfly front sprocket and what size did you go for?
6,714
sort of screwed on that one unless you can grind away the plastic with a dremmel ect.
or just remove the plastic case tho it might look kak with out it.
Trekkie
19
Leicestershire
15 to 20 teeth is a huge change in gearing. You may well be happy with a 16 or 17 tooth sprocket which will likely fit straight on.
Hi Thanks for the response, yes it is a big jump but from what I had read the bike had a 17 tooth as standard, but that wasn't the case. I will try a 16 or 17 and see how I do.
Regards
Trevormonty
1,135
564
18
NZ
Regards
Why do you need higher gearing, 15t should be good for 40kmh in top, well above 25kmh assist cutoff.
6,714
unless you have a dongle there is no way you will keep up with that.
6,714
