Bosch Powerpack 500 - will it fit a Powerpack 300 mount?
Warwick
731
225
Warwick
As it says in the title. If I buy a Powerpack 500 will it simply slot into the mount of my Powerpack 300?
Is there any other factor to consider? Is it simply plug 'n' pedal?
Trevormonty
1,135
564
18
NZ
Should do, I swap between 400wh and 500wh all time. NB when 400wh came out it was compatable with 300Wh.
Reactions: Danidl
You do of course need to check that the generation is correct .. there are differences between the classic and the current ranges.,There is now also a difference between the current and the more stealth in frame versions. Also you need to check whether the battery pack is the carrier mounted version or the up tube mounted one. I think the package is different.
