Brake cut off levers - Black?
RichB
68
Hi,
Having just installed the BBS01 kit on my Cube mountain bike, there's just one thing that's annoying me.
The brake lever I've fitted from the kit (only fitted one as the brake/shifter is one unit, so just removed the front deraullier and shifter/brake) is a chrome colour. However the stock is a black lever.
Can you get black levers with the cut off switch, as I'd like it to look as 'stock' as possible.
Many thanks,
Rich
2,905
56
RichB , do you have cable or hydraulic? The kit levers are functional but really cheap and nasty.
Assuming cable brakes, there's loads of options for switches that don't include levers. There's in-line brake switches or you can make your own.
Kinninvie
888
399
Teesdale,England
You could always paint it black.
RichB
68
Hi,
Cable brakes.
I had thought about painting them but I'm not sure how hard wearing that would be, as I'd imagine that the paint would be prone to chipping/cracking.
I'll have a search for a switch, any recommendations?
trex
7,703
2,669
Have you considered removing the brake sensor to fit to your hydraulic brake handles? the sensor is a Hall, the lever pushes a rod which moves a 2mm magnet in front of the Hall transistor, turning it on/off.
I imagine a bigger magnet glued to the brake handle may do the same job.
trex
7,703
2,669
it has 3 pins - Hall sensor. Simplest solution is to remove the sensor wire (quite easy, it took me just 2 minutes to remove the lever from the handle and push the cable out), remove the existing magnet and replace it with a bigger one.
yello brake connector:
Brake handles:
Reactions: RichB
RichB
68
Thanks for all the info, I'll have a closer look at them when I get home tonight.
Obviously if I could do something with the existing brake levers rather than buying a new set, it would be beneficial.
2,905
56
This is mine RichB, the magnet has now been replace with two smaller ones(which sit better) using epoxy glue. You will need to cover the exposed hall sensor with a bit of heat shrink to prevent moisture. I was able to drill thru the back of the brake body to insert the heatshrunk cable sensor wire.
Tomorrow I will upload a new pic for you.
Reactions: RichB and trex
RichB
68
Thanks Nealh, that pic is useful.
Was a bit dark when I got in but I'll see if this is feasible tomorrow.
Thanks again.
2,905
56
Forgot to mention RichB if you haven't already sussed it.
Place items in a temporary position lift back wheel, apply throttle wheel will rotate then apply brake and magnet should be sensed and power will be cut. This way you can adjust magnet to get the correct proximity for the sensor.
008 break on magnet sensed, throttle disengaged.
007 break off magnet unsensed ,throttle working.
cwah
2,973
174
www.whatonlondon.co.uk
trex
7,703
2,669
if you have 3 wires on the controller side, two of the wires are ground and 5V supply, the third wire is the signal. There are two possibilities: brake signal is active low or active high. You need to find that out first. If it's active low, then it's easy, just ignore the 5V wire.
cwah
2,973
174
I'm using these cut out brake:
http://www.aliexpress.com/item/The-power-modified-electric-mountain-bike-brake-Power-cut-off-swith/1872462748.html
I'd like to wire it to my controller that has 3 wires. Do you know how I should do that?
cwah
2,973
174
It only has 2 wires. I don't know if it's low or high
trex
7,703
2,669
you can check which wire has 5V, usually red, which is ground, usually black. You only need connecting ground and signal to the brake switch.
Reactions: cwah
