Brightest light for not silly money
Malcolm Stephenson
97
39
49
My commute was destined to change but I have deleted the move
It leaves me having to cycle should I choose to over the dark night season
I cut down a long unlit section of a cycle path running parallel to fields for approx 4 miles no cars any where in sight so I need a cheap super super bright lamp for that section to light the way
Plus I like torches in general so the brighter the better
Something like one of these or even brighter if poss
http://www.ebay.co.uk/itm/151886495410
Already have a couple of smaller Crees for lower power light us the inbuilt light
I know the lumens they list in these listing is taken with a huge pinch of salt
Thank you in advance
Reactions: LeighPing
Gaz
720
556
55
Eastbourne
Gaz
720
556
55
Eastbourne
Is the battery life as good as quoted ??
Actually yes. Doesn't make sense (to me) that it lasts as long as it does. USB charging from a PC too. Noticing they're out of stock though, so you might have to look at a similar current model. Very well made bit of kit, no separate battery to faff around with.
That one in your link is the one I had that drowned. It was the battery that committed hari-kari. Waterproof it in a plastic bag and it might well be okay.
Gaz
6,722
6,722
Trevormonty
1,135
564
18
NZ
Gaz
What is handlebar mount like?. Will it handle serious MTBing without moving.
I've found screw tightened mounts good off road.
egroover
1,095
655
58
UK
Reactions: Malcolm Stephenson
Gaz
720
556
55
Eastbourne
What is handlebar mount like?. Will it handle serious MTBing without moving. I've found screw tightened mounts good off road.
It's a screw tightened one, and blooming good. I don't do serious MTBing, but it's rock solid, so I wouldn't doubt it for a moment.
Gaz
Malcolm Stephenson
97
39
49
Just picked up a handlebar bag for that very purpose of battery housing
8,788
Malcolm Stephenson
97
39
49
  • Dislike
Reactions: Tugwell Gibson
That one is perfect. I use one every time I ride at night. I tried most of the other Ebay, Aliexpress and Banggood ones first, but that one would take some beating. I can't believe that anybody would need any more light.
8,788
Go for it Malcolm a bit more Lm quoted then the one I linked to, even the 3000lm is very very bright.
LeighPing
2,547
1,945
The Red Ditch
You'll need one like this, as yours doesn't contain a battery pack.
http://www.ebay.co.uk/itm/3000LM-CREE-XM-L2-LED-Head-Front-Bicycle-Bike-Lamp-Headlight-Hunting-6400mAh-AC-/161891967934?hash=item25b18363be:g:i58AAOSw6dNWTd5w
Here's a couple of videos I made of mine.
It's a superb light. :)
1.JPG 8.JPG 4.JPG DSC00912.JPG DSC00918.JPG Headlight battery pack.jpg DSC00744.JPG Barking2 BELL.jpg
