Brompton nano PAS removal
jonpedal16
South Norwood
I've a brompton with a nano system along with a pedal assist sensor and a throttle, but I'm finding it a bit underwhelming due to the pedal assist not coming on when I need it when I have the throttle on. I'd like to remove the pedal assist altogether as I have mobility issues. There's a clear wire from the pedal sensor to the controller, I had hoped unplugging that would do the trick, but that just results in no power at all. Does anyone have any ideas what I need to do? Thanks in advance.
3,986
Can you explain that again in different words. It doesn't make sense. I read it as the throttle is working, but the pedal sensor doesn't do anything when you operate the throttle, which is normal because the throttle takes precedence. You want to improve that by removing the pedal sensor!
jonpedal16
South Norwood
Apologies, the current setup I believe is that it needs both the throttle pulled and pedals to be moving for the motor to kick in, current EU laws I suppose. However, I think because the sensor is relatively basic I find that the motor doesn't kick in when I need it, there's a small/medium lag. It's actually not very fun to ride, the motor only feels like it comes on when I'm already rolling under my own steam, rather than help me get rolling.
My hope is to remove the pedal assist sensor, so that it only needs me to twist the throttle. Like a moped I guess, which given I'm riding around on private roads it's not really a problem.
Just unplugging the pas sensor from the controller alone does not work, I assume the controller needs signal from both the PAS and throttle for the motor to turn.
3,986
OK, got it now. It never ceases to amaze me what crappiness some suppliers can get into their kits.
There might be some way of fixing it, otherwise a new controller will sort it out. It's difficult to comment without knowing exactly what you have. Photos of all the connections to the controller will help.
16,457
unfortunately, it's the law since 1/1/2016. If you don't have to pedal before throttle, then your throttle is a twist and go.
You have to change the firmware in the controller to make yours twist and go.
pedalingDave
12
I remember talking to Tony (who invented the nano kit) and I think he said that the cadence sensor was relatively simple and you could change its behaviour by adding more magnets at the chainwheel. That would reduce the lag before it kicks in. Of course, my memory could be wrong!
16,457
the Gospade has 120 magnets in its pedal sensor for that reason.
3,986
There's no law that says that you have to have a massive delay before the oedal sendor kicks in!
3,986
I very much doubt that that will work. The delay comes from the controller software. Some controllers take ages to figure out the position of the motor before they can send the commutation pulses.
jonpedal16
South Norwood
Thanks, I will look into this, hoping this is as simple as glueing more magnets onto the sensor
jonpedal16
South Norwood
Thanks to you all, I've a few leads on people to ask but I found this as a sales blurb...trying to understand if throttle and pedelec system use the same controller or if there are seperate controllers for each...meaning I'd have to change my controller.
Throttle or Pedelec.
There is a choice of either a half grip twist grip or thumb throttle which are spring loaded, smooth and proportional or alternatively a pedelec (pedal assist) system.
The half grip twist throttle, is fitted as standard to the right handlebar. The speed can be regulated by twisting the hand throttle up to the legal speed limit of 15 miles per hour. There is a button to switch the system ‘on’ and ‘off’ and LED lights on the throttle to give an indication of the battery charge.
A thumb throttle isavailable on request and is required for P handlebars. It is also fitted on the right handlebar but does not require the handlebar grips to be changed, just removed to fit the throttle. The thumb throttle is activated by holding back the paddle, like the twist grip, the further you push it back the faster you will go.
The pedelec replaces the throttle and gives a range of 6 speeds that are pre-selected. You need to pedal first when using a pedelec which is not the case with the throttles. The Pedelec is a legal requirement in the EU and some other countries.
The throttle, or pedelec, 36V electronic controller and modified luggage block are all supplied as a complete wiring harness."
8,226
Speed controllers generally have no PAS output, so you need a controller that offers both an outlet for PAS and throttle.
8,226
I have read this again and understand it now, the pas/throttle usage is not stand lone throttle. Since 2016 throttle operation is only possible (legally) once you have engaged the PAS, it is to remove the moped style control of throttle only.
The controller you need is KT model with matching LCD, buy them as a pair.
The settings will allow you to set the throttle as pedal first option or stand alone throttle with out PAS use. Wiring connectors may not match you existing set up so you may need to do some work soldering.
jonpedal16
South Norwood
Thanks, I had hoped it'd be a simple job, but sounds like I need a new controller and new wiring. Ouch.
8,226
