Can a sinewave controller run sensorless
1boris
343
58
I read on endlessphere that s06s controller could run sensorles.If thats true.Can I use a bafang Bpm 2 sensorless motor with one of the new bottle batterys from BMS Battery with an internal sinewave controller?
1boris
343
58
Forget about it,I must have been reading wrong.I couldnt find the post again.Are there no batterys with an internal sensorless controller?
Most of the BMSB BPMs are sensored, so you can pair one with the nice 09 bottle battery with the integrated 20A sine wave controller. I think you might have to do something with the motor connectors ecause I believe that the controller has the nine pin connector. Another good alternative would be the Q128H, which has the correct connector. At 48v, it should provide a lot of torque. I can only see 201 rpm at 48v, so use the 36v one at 48v for more speed.
