Please can anyone advise me of fitting new switch, can i use any rate keyswitch as long as two terminal or does amps or watts come into this at all ? my present one reads 15a 115v what is the lowest vaue i can use
thanks
Hi Geostorm. Amps does come into play. If you fit a switch with too low a current rating, it can melt when you're using it. Go for something rated at 15A or higer and you'll be OK.
