My old Powabyke Euro has a faulty throttle so I bought a new one. Unfortunately it doesn't work properly because the original throttle signal decreases from 4 volts to 1 volt as you twist it and the new throttle increases from 1 volt to 4 volts as you twist it. Twisting the throttle moves a metal strip past a sensor. If I remove the strip, turn it round and put it back in will I be able to use it do you think? Has anybody already tried this?
