Hi Pedelecs.co.uk !
Now that I benefit from the Cycle Analyst readout on all my cycling trips, I have a better idea of how my Bafang setup performs.
I noticed that the current draw rarely climbs over 10A, or just under 400W peak. This matches the 1C rating of my 36V Li Ping LiFePo4 battery (10Ah capacity), and it only occurs for short bursts, i.e. when climbing hills (by the way, the voltage doesn't sag with this kind of discharge). This also seems to be the factory rating of the motor itself, so I am using it within the designed tolerances (note: this is a 255rpm motor, used on my 16" Brompton wheel).
Given that the Bafang is known to be reliable when "overclocked" to 48V, I wonder if I should be able to "push" more power into the motor with my current 36V setup ?
I think the power cutout currently programmed into the controller is around 12/15 Amps, but I need to figure how much exactly. The Ampere limit on the Cycle Analyst is way greater, I am not actually using that protection feature yet.
According to Li Ping's specifications, the battery is able to deliver more power:
Rated Discharging Amperage: 10 Amps
Max Continuous Discharging Amperage: 20 Amps
Maximum Discharging Current: 40 Amps
Discharging Cut-off Protection: 25-30 Amps
36V 10AH V2.5 LiFePO4 Battery Pack
So, can I technically get more power out of the Bafang if I increase the controller protection threshold ? (e-Crazyman / Keywin Ge / Infineon / Shenzhen Sucteam / EB806-XC-C-3 controller + USB cable with ParameterDesigner.exe software). More importantly, how safe do you think it would be ?
Many thanks,
Cheers, Daniel
Many thanks,
Cheers, Daniel
