Capacitors in KT Controller blown
Theophilus
11
My ebike was failing when going up steep hills. I would switch it off for 20 seconds and then the motor would start again. This failure slowly got more regular and worse. Yose Power said the motor was faulty and, as it was still under warranty, they sent a replacement. I finally fitted the new motor and set off, and after 100 metres it failed. And this time it wouldn't re-start.
This got me looking at the Controller ( KT36ZWSRT-01). The two capacitors on the circuit board looked suspect and my friend, who is a deft hand with the soldering iron, replaced them. My ebike is now fully working again. Cost of components less than a fiver.
I am now looking for a wheel so I can utilise my spare motor :)
8,781
I doubt if the caps had blown because when they do the evidence will be clear to see and smell.
When the bike fails on hiils it is usaually due to slow speed and too much current on steep hil, this causes a lot of heat and the mosfets will eventually reach their olsp temp and thermally cut out bt temporary shorting. Once cooled they will switch again until they get hot again, better mosfets are needed or more mosfets.
Theophilus
11
It looks like the heat from the adjacent resistor (which looks like a wire link), which was excessively darkenened by excess current, melted the plastic covering of the capacitor and caused the top of the capacitor to expand. There was no visible damage to the mosphets.
StuartsProjects
1,857
1,040
But what caused the damage, is it likely that both capacitors were heated and melted at the same time ? If it were my bike I would be curious.
Electrolytics do fail, due to overvoltage, or not having been used in a while. The start gassing internally and to stop them injuring people they normally have weak spots, triangular lines, in the stop of the alluminium can.
Did the capacitors have a suitable voltage rating ?
Theophilus
11
I burnt out the previous motor after climbing a long and very steep hill. The heat generated by this probably contibuted to the eventual failure of capacitor.
Ive no idea if the capacitors had a suitable voltage rating. I guess they did as the controller came as part of the kit.
Theophilus
11
Photos showing the blackened resistor and the two capacitors, one with a split plastic cover. The assumption is that the resistor overheated and transferred the heat to the capacitor causing the plastic to split in the process.
StuartsProjects
1,857
1,040
Well, its possible the current measuring resistor got hot enough, cant say I have touched one when the controller is in use. I have a similar KT controller and it did get failry hot the other day going up a long steep hill an max assist.
The capacitors in the picture are 50V so OK for a 36V battery.
WheezyRider
1,690
938
The 470uf 50v capacitor showing the melted plastic covering
Yep, that capacitor has blown. Have a look at the top, it is slightly bulged. There was a huge problem with dodgy electrolytic caps 10 to 15 years ago, causing all sorts of electronic kit to die prematurely. I used to be given loads of "dead" motherboards and get them running again by replacing the caps. You'd see bulging at the top initially, then soon after they would often short and fail with a bang. There are probably still some bad caps out there on the market in China.
Good job getting it sorted :)
StuartsProjects
1,857
1,040
I used to be given loads of "dead" motherboards and get them running again by replacing the caps. :)
BTDTGTTS.
If you had a controller apart and found one capacitor bulging, would be an idea to replace the lot, they are not expensive.
WheezyRider
1,690
938
BTDTGTTS.
Soooo true :D
Another thing to check I find with a lot of modern lead free soldered PCBs is the quality of the joints on electrolytics, they are often loose and could do with a drop of fresh solder.
StuartsProjects
1,857
1,040
Especially the surface mount ones.
It does not take much of a knock to break the (tiny) soldered joints.
Lead free - orrible stuff.
Reactions: WheezyRider
Balmy
16
Hi All, am new to the forum, just joined. I have a kt controller that is not working. The board looks exactly like this one in the pics. The shunt resistor is a bit charred and the big resistor next to it also had a bit of black on the legs. I removed it out of the board and it measured 198k ohms. What is the value of this resistor? I cant exactly tell what colours the bands on the resistor are.
cheers
AntonyC
392
169
Surrey
The one in Caps2.jpg could be 1K 5% 1W. But both boards look darkened around the shunts, suggesting they're overheating enough that problems will recur.
You could reduce the controller's maximum current to 80% so that the shunt makes 2/3 of the heat, or try replacing it with a string of physically larger shunts, but that only helps if the problem's the board design. I'd have guessed at a shorted winding if OP hadn't already swapped the motor.
Balmy
16
Thx for the speedy response. Attached is a pic of the resistor on my board. Like i said i pulled it out and measured it and it shows 198k ohms. I dont know its value, so i dont know if its busted and whether i should replace it or not. Attached is a pic of my controller model.
AntonyC
392
169
Surrey
That too _could_ read 1K and it's failed open circuit: if it were more than 7K a smaller and cheaper one could have been fitted. The cause of failure still needs finding and fixing.
