Carrera Crossfire E - first cut out (Sport Mode)
fredtop
17
55
St Helens
Hello, I had my first cut out on my 2 month old (160 miles covered) Crossfire the other day. I've checked all the threads on cut out problems and can't find anything specific to my question.
I have the revised model with the new LCD (Eco, Tour, Climb, Sport).
The cut out happened on a hill I have covered many times in Climb mode, but this time for some reason I tried it in Sport mode and it cut out completely after about 1 minute.
I just wondered if Sport mode could be the reason? - I know with the previous model the mountain goat was the top assist mode and one presumably intended for hills, seeing as how well goats climb mountains.
Just wondered if Halfords / Suntour are aware of this so changed the climb mode to the 75% level instead of 100% to prevent overheating or something??
Any comments or suggestions from other Crossfire owners or anyone who knows about this sort of thing would be great.
Reactions: LeighPing
Fordulike
3,802
1,538
If this happened when the battery was nearing empty, then the battery may have dipped below the battery cut-off voltage in sport mode. This would cut the power until reset. It's just one of those things with some set-ups, and as you discovered, reducing the assistance mode helps. If this is happening with a freshly charged battery, then get the battery checked under warranty.
fredtop
17
55
St Helens
Thanks for the comment Fordulike - it wasn't freshly charged or empty, I was coming home from work so think it would have been in the 40-50% region.
Maybe it was just one of those things, just a bit strange as I haven't used Sport on hill before. I'll try it again and see what happens.
Fordulike
3,802
1,538
I'll be honest and say that I doubt that the Crossfire-E battery pack contains high spec cells. I would guess that they are generic Chinese cells, so probably more prone to battery sag, than the likes of Samsung 30Q's. With a half empty battery pack, I would expect the voltage to drop quite a bit in top assistance mode.
8,788
I suspect most of the cutting out issues are related to which cells are used and configuration.
redcup1999
213
126
Bristol
And to the way that the controller is programmed with regard to current draw - even in ECO mode you can get extremely high current demands by stomping on the pedals. I used to get cutouts in ECO mode in the "right" circumstances. (Go down a steep hill pedalling like billyo at 20mph +, start pedalling up the other side of the hill - when the speed drops below 17mph and the motor cuts in, stomping on the pedals could cause my motor to cut out even in Eco mode).
fredtop
17
55
St Helens
Do you think there is a reason for Suntour changing the climb modes?
Its like they don't want you to use a 100% assist on a hill, or is there something different with the torque in climb mode?
8,788
I can't see the amps draw being much more then 17/18a, if cells were decent 10a rated ones there should be no issue with sag or heat and in theory should last a good few years if used regularly. Problem is a lot of batteries will use so so 4 or 5a rated cells that don't really handle very well even with 5 in parallel.
We need someone brave enough to open one,
Fordulike
3,802
1,538
http://www.halfords.com/cycling/bikes/electric-bikes/carrera-crossfire-e-mens-electric-bike
The technical jargon suggests the Climb Sport 100% mode is for riding up hills at speed. I reckon it'll live up to the name with a fresh battery, but will struggle to provide the amps the controller needs, once the battery pack empties to a certain level.
