Carrera vengence conversion
wweewewewew
I want to convert my medium fraame carrera vengences but dont know what kit and battery to use it should be 1500w-2000w and needs to be hub motor it would be nice if it came with a tyre on the wheel but it isnt required im looking for it to be about 400-650 pounds.
matthewslack
2,437
1,609
Wrong forum for that kind of motor.
A 250W conversion will be fine unless you intend to ride at illegal speeds.
matthewslack
2,437
1,609
its not for on road use
Yeah, right!
Even off road it is illegal, unless the land is private and the public don't have access to it, and you have the owner's permission. Almost none of the UK falls into that category unless you are a Lord... which perhaps you are!
Reactions: RumbaAzul
wweewewewew
Yeah, right!
My grandad owns about 2 acres of land and that will be where the bike lives
matthewslack
2,437
1,609
Bikes such as you describe don't work off road, because those big hub motors are direct drive, and not happy at low speeds. Their design purpose is high speed cruising on relatively flat surfaced roads.
So if you want a bike for riding round in circles in a 2 acre field, you need something different. The types of 250W geared hub motor or a mid-drive conversion that work well at legal speeds on hilly roads would do just fine.
8,760
The clue is in the forum name, ie Pedelecs .
A pedelec is a 250w push bike that adheres to UK regs.
A 1500/2000w conversion is a moped come motorbike as defined by DVLA .
wweewewewew
its quite literaly a flat feild with short grass
8,760
Problem though is there is little policing of e-mopeds disguised as e -pushbikes,
I see them often where I live as many other will do in their localeand , users riding with no pedal input , a dinner plate in the rear wheel and riidng at speeds that doesn't shout rider input.
#9 there is one with a very similar set up or could even be the same set up locally here that one can hear coming.
