Changing when PAS kicks in on BBSHD
Gagsinio
64
48
Hi folks, is it possible to increase the amount the pedal needs to turn , before the PAS kicks in. My Oxydrive kicks in after about half a pedal revolution, but the BBSHD seems to kick in much sooner, so if you wheelie up a kerb, you risk going through the window of the shop you were intending to visit. I have a programming cable, just wondering which setting to change?
Cheers,
G
Fordulike
3,783
1,524
IIRC, change the Startup Degree(Signal No.) to a higher value in the Pedal Assist page.
If you have brake cut-offs fitted, squeeze the brake lever slightly when pedalling up a kerb. This method works for me.
tommie
1,746
595
Co. Down, N. Ireland, U.K.
Startup Dgree(Signal No.): 4\4\4\4\2– The number of sensor steps before the start up commences. The maximum accepted is 20. 24 is a full pedal revolution. Too few makes start-up occur with too slight a pedal movement. Lower number is less pedal movement to start the motor. Does not work properly with 1 or 0.
here you go..
https://electricbike-blog.com/2015/06/26/a-hackers-guide-to-programming-the-bbs02/
