Help! charging problem
mikenewman63
12
Hi all. If I plug my charger into the frame without the battery installed should the display read full or empty please i have a charging problem
Gliggsy
96
32
Don't know about a charging problem but you've definitely got a lack of information problem!
3,986
You solve charging problems with a voltmeter. Measure the voltage on the connector on the charger, then measure it on the battery's charge socket. Those two results should tell you where the problem is and, by deduction, what it is.
8,226
One would need a verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrry long extension lead to go for a ride .
Reactions: pentiumofborg
mikenewman63
12
what i mean is my display is showing 1 bar instead of 7 bars when battery fully charged tried another charger, still the same, battery is showing full on multi meter, but bike not working past 5 miles . i was wondering if the charger was plugged into the socket on the bike if it should alter the display because it is reading the same as when the battery is in or out of the frame
mikenewman63
12
8,226
What voltage did the meter give for the battery at said full charge ?
If the lcd is displaying a low battery one can bet it could be correct.
mikenewman63
12
sorry
what i mean is my display is showing 1 bar instead of 7 bars when battery fully charged tried another charger, still the same, battery is showing full on multi meter 41.85v , but bike not working past 5 miles . i was wondering if the charger was plugged into the socket on the bike if it should alter the display because it is reading the same as when the battery is in or out of the frame
8,226
Battery voltage is good .
Does the lcd have settings to change voltage reading i.e., 36 or 48v ?
Its appears that the correct voltgae isn't being read/displayed correctly so a setting or faulty controller.
Are you able to identify the V+/V- on the lce connector from the controller and take a voltage reading ?
The cutting out after five miles indicates lvc is being hit so either the battery, controller or a setting as already indicated.
mikenewman63
12
The cutting out after five miles indicates lvc is being hit so either the battery or controller .
thankyou what is the controller please
mikenewman63
12
Thankyou vfr400 dont know how but ive just messed with display buttons and its now all fixed thankyou very much.
8,226
In that case then one suspects lvc was cutting in and the system thought 48v was the supply, once voltage hit 40v or so it simply stopped.
3,986
I think that's three times I've seen that on this forum. It happened to me once before we had LCDs. I bought a 36v controller that turned out to be a 48v one. Luckily, there was a jumper inside that converted it from one to the other.
Deleted member 33385
A freaking jumper INSIDE? The OP was lucky it was just a setting on the LCD!
