Compatability 500 to 250w
flip123
I have a 500w direct drive front wheel motor with a KT36ZWSRMT-LCD controller and a KT3 LCD display.
The motor has drag if you want to pedal without electric so was considering changing the wheel for a 250w geared motor with a freewheel and wondered if my controller/display would be compatible.
8,224
Yes, perfect for geared hub. What is the controller current rated for ?
Is the KT sensored ?
As you have found out D/D hubs are pig to ride unpowered a geared hub will allow unpowered riding though hills will still be energy sapping.
flip123
Rated at 11A Max 22 +or-1A
Sorry i dont understand what sensored means
8,224
How many motor wires ?
Unsensored = 3, sensored 8 or 9. With KT a sensored model has 6 thin wires in to a white square connector block.
8,224
Your hub and controller are sensored/sinewave, you have the DJ7061 white connector block with the six very thin sense wires connected.
3,986
You can use any of the medium oe large geared hub-motors. Make sure you get one with the speed you want. 201 rpm for 15 mph 260 rpm for 20 mph and 320 rpm for 24 mph (26" wheel).
flip123
Most companies only sell kits I only want a wheel any suggestions please?
