Help! Connecting headlight to BBS02
Deleted member 33385
Which one goes to which? Black/white and black wire comes from bbs02 and red and black wires comes from lamp.
I went black to black on my BBS01b, ignored the other colours - it's easy to tell if you've got it wrong, because the LED in the headlight doesn't last long. Mine's working fine.
Reactions: mt247
mt247
111
17
Thanks, I'll try this.
You know what this connector type is and how to pull them apart once you connected them?
They're crimp connectors - you can use a crimping tool, it's best to solder them, but I just tightened using a very large set of pliers... will get around to soldering.
You can undo them by prying using a small flat screwdriver.
Reactions: mt247
8,226
Black/White indicates that it is the v+ side.
Reactions: mt247
