My Oxydrive integrated battery controller is now unbelievably noisy you can here me coming from 50 yds away, the controller is a solid state Luishi and very thin.
I have a fried 36v KT with 9 pin motor cable and 8 pin 4 in to 1 cable and a dual voltage S/W KT.
In practice how possible is it If I swap/splice the wiring from the duff one to the good one replacing a lot of spaghetti and wire connectors ?
The two KT's side by side.
Left one new controller with spaghetti, right duff one with 2 main wire cables.
The 9 pin motor wire is easy, I can cut and shut in side the controller case.
The 8 pin is not so straight forward 7 wires I can fathom out.
The following colours are labelled as such on both controllers
Blue / DM
Red / N
Black / G or G1
Yellow / RX
Grey / TS
Green / TX
White / S1
Mauve / TH on old controller, new dual model only has TV solder port.
Blue / DM
Red / N
Black / G or G1
Yellow / RX
Grey / TS
Green / TX
White / S1
