Correct battery?
Do I have the correct battery?
  • technical
    Votes: 0 0.0%
  • general
    Votes: 0 0.0%
  • Total voters
Rod Fuller
73
85
Ordered Li -ion 48V 20Ah, delivery note says 3.2V 10A
Before using this battery, I need to know if I have the item that I ordered
double cell would give say 15 x 3.2 = 48, current output?
Perhaps a link to what you ordered might help.
Alan Quay
2,351
1,076
Devon
I expect there's a capacity limit for shipping, so the test report shows the battery as being under this. I've had similar test reports with chinese batteries.
Rod Fuller
73
85
That's one monster of a battery. It must weigh 12kg. What are you going to use it for?
Rod Fuller
73
85
That's one monster of a battery. It must weigh 12kg. What are you going to use it for?/quote]
Not at all
Dimensions of metal case:L34.5, W15, H 8cm. Wt 4Kg
Manufacturer's spec:20Wh per cell, 100Wh per battery
I still do not relate this to 48V & 20Ah
Did you put it on the scales to weigh it. My 36v 10ah Headway battery weighs 4 kg. It has 12 10ah cells. Yours should have 32, so should be 2 1/2 times heavier. Also, it should be 33wh per cell.for 1056wh total. The 100wh is only for the shipping paperwork because that's the maximum you can send.
Reactions: Rod Fuller
Rod Fuller
73
85
Did you put it on the scales to weigh it. My 36v 10ah Headway battery weighs 4 kg. It has 12 10ah cells. Yours should have 30, so should be 2 1/2 times heavier. Also, it should be 33wh per cell.for 990wh total. The 100wh is only for the shipping paperwork because that's the maximum you can send.
Yes I did weigh it, apart from that from what you say I am still not convinced I have the battery I ordered.
If you weighed it, what is the weight? Are you saying it's really 4kg?
trex
7,703
2,671
you should see 38120S 10AH printed on the side of the cells.
trex
7,703
2,671
maybe, but I wanted 20Ah! Nothing printed on the metal case.
You can check the size of the cells easily.
38120 cells are 38mm wide, 120mm high.
If not, give us the dimension of the pack or post picture we'll check for you.
Rod Fuller
73
85
Dimensions of battery box were given previously wt between 4 & 5Kg
trex
7,703
2,671
that case holds only about 48V 10AH in LiFePO4 top.
I don't think they sent the right battery.
