Could this be a lead-acid battery?
rogermunns
20
I have acquired a second-hand bike with a dead battery. Apparently 7 - 8 years old. I have bought a new Li Ion battery which is very similar in appearance to the old one. The question is because the new one weighs 2.7kg while the old one weighs 4.9kg. This seems a very big difference ..... any thoughts?
KirstinS
3,224
899
Brighton
Lithium has changed a lot in 8 years. You can get far greater capacity in a single cell these days compared to back then
So you need fewer of them to make the same Ah and voltage battery.
2,652
Pictures of the two, especially any labels they have which may give more info about what's inside them.
Or if pictures are awkward, what any labels say.
Reactions: KirstinS
KirstinS
3,224
899
Brighton
It's impossible to say without more details.
Yeah for 100% I guess you're right but I cant see how a 36v lead acid could ever get down to 4.9kg (each 12v pack being c3kg)
I'll eat my hat if this isnt a matter of improved lithium tech or a reduction in Ah or both. So not lead acid vs lithium
*leaves quickly to purchase a chocolate hat*
8,173
Show us pics of the old one and it's charger it may be a Lithium phosphate aka lifepo4 celled battery, hence the weight difference.
Reactions: KirstinS
3,985
What's the output voltage of the charger - written on the label?
Which bike is the battery used on?
How much capacity did the original have?
Another possibility is NiCad or NiMH for the original, but without details, all we can do is guess. Time to kick yourself Kirstin. I'll want to see the vid of the hat being eaten! If it's a chocolate one, I want half.
Reactions: KirstinS
30,349
At 4.9 kilos possibly an NiMh battery as VFR says. For example when Ezee bikes were offering an overlap choice of NiMh and Li-ion for a while, in the identical battery case, they weighed 4.2 and 2.5 kilos respectively.
I'm sure only Heinzmann used NiCad more recently than the last 15 years, so that's less likely
Reactions: KirstinS
KirstinS
3,224
899
Brighton
Maybe ! But not until OP comes back to us
*leaves to bribe OP via DM ;) *
Ps I'm banking on old school prismatic cells vs newer tech. Based on zero info
8,173
I think Alan has posted on the wrong thread unless he has decided he no longer wants to be rogermunns :p.
rogermunns
20
Hello again all. Mystery solved with the pic by flecc a couple of posts ago. I have only just seen this, pardon me.
Last night I slit the aluminium (english spelling) with a dremel. It had been totally impossible to push out the contents (after unscrewing the ends). As I slit along the 39cm length of ali sleeve I found out why the internals were fixed so tight. Because as I cut, the ali split along, such was the force being exerted by the metal insides.
Now for the pics. Sorry they are big, I couldn't find how to reduce their size.
First; the split-apart case plus the internals (one cell had been snipped off for separate photo)
Second; one of the 10 cells with a DVD to show scale
Three, four, six; the bike SWIFT Zoom 4
Five; the charger.
Again, sorry for delay, us 74y.o.s are very busy!
Reactions: KirstinS
rogermunns
20
It might be thought 'of course, they are Li-Ion 'because the charger' says so. But the widow of the guy who had the bike told me she wasn't at all sure that the charger belonged to THAT bike, because he had others and it might have been for one of them . The bike I have was in a garage even more messy than mine, with many electronic bits all over the place.
3,985
They're Philyon lithium cells, the same as was were in the early Ezee batteries and many more similar ones. It's a standard silver fish case, so your modern one will be OK. Just check that the terminals are the right way round. it's best to check at the controller connector before connecting that the red is the plus in case there's any cross-over anywhere else.
Looks like Kirstin doesn't have to eat his hat after all. Blast!
Reactions: KirstinS
rogermunns
20
Thank you. I suppose the Philyons are beyond recall? Maybe 6 years since they were last used. Out of the single one is coming 0.3volts.
Reactions: KirstinS
