Cube Reaction Crankset
Gary F
Sep 15, 2021
I have a 2021 Cube Reaction Pro 500 which has a standars ACID E-Crank, 38T . I have just had to change the cassette having worn through the smallest 12th gear after 4000 miles. I do find it under-geared for me as I spend 95% of my time on that cog. Has anybody fitted a larger crank cog to this bike. There doesn't look a great deal of room with the frame recess. Any info much appreciated
Ballynoes
257
146
Perthshire Scotland
I use my MTB (Cube Reaction Race 500) for climbing, mostly in the hills etc, so I did the opposite, I changed the crank to a smaller one, so I can climb Munro's etc.
It was just a case of finding the correct crank cog and fitting it, I had to shorten my chain by a few links also as I was "downsizing"
From memory I just started to Google it and found a site which sold just the thing.
Not difficult to change, just getting the right one was the issue.
You could also change the cassette in the rear wheel for a different range if you can, might be an easier option.
Here is an example -
6,319
Related Articles
