cyclotricity bike cutting out
Peter farrall
Mar 12, 2017
Chester
Hi all
I have a cyclotricity kit on a Marin mountain bike with 250w front wheel motor and bottle battery which has done about 18months and 2000 miles
It started cutting out on wet days so I sent the kit back to Cyclotricity who checked it out and sent a new battery
It still played up on wet days so I bought another LCD controller (since it sometimes steamed up after rain)
Still had problems after rain and now (having "dryed out" the Bike it still constantly cuts out requiring me to stop, switch the battery of and the on again, then the LCD will fires up again but the bike only goes for 5mins
Has anyone had this problem, could it be the control unit? I have checked all the wires, connections and the pedal assist kit on the crank that seems to be OK
Peter
D8ve
2,142
1,294
Bristol
What about brake cutouts?
8,788
Have a look at the pas sensor as my Oxydrive did this in the wet early this year, moisture gets in and shorts the 5v line so after drying out I sealed it up again esp at the cable entry.
It has been worked fine since.
If the LCD goes off, it's either gone to sleep (no speed signal) or the voltage between the battery and controller has been interrupted.
8,788
For sealing I use a butyl flexible sealant, it come out of the tube really icky but once cured by air it remains pliable and mouldable. I use it on all cable entries esp on my bbs01.
