Battery died on way home
Showed 75% so I charged it up which seemed to work just fine. Then showed 100% on the LEDs
I have tested the power lead, the battery terminal - both dead.
Then took base off and tested fuses and the power leads before the enter the fuses. Fuses fine but no power.
Next I took top off battery where BMS is. There are two negative / black and two positive red (on photo the red are at bottom and black are top right and top lef just by the plastic
If I test the top right black with either of the reds I get 41.4v. If I test the other black wire against either red I get zero v
Any ideas here ?
If the battery charged then the bms must be working , right?
Any ideas here ?
