Hi all , I’m looking at a fairly standard 36v rear hub setup that had a sudden total power failure
I’ve check battery, outputting full 42v
I’ve checked the controller is getting power, fine
I’ve checked power is going to lcd , fine
I’ve checked the remote switch (see pic) which is getting full voltage to red and black)
But still lcd won’t switch on
So I’m thinking either switch or lcd has packed up
If I connect red to black on the switch will this bypass it and turn on lcd ? I presume the other two wires are signal wires for the up/down pas level. No throttle on the bike (though the controller seems to have the plug for one ) I
Main lcd plug at controller
Lcd underside (right side goes out to remote switch )
And the remote switch innards
Thanks all
Thanks all
