Display compatability
atheo
102
12
Beds..
I have a Kunteng 36v 500w 9mos square wave controller that is not compatable with a KTLCD3.Does anyone have an idea what display would be compatable please?
8,212
In which way are they not compatible ?
atheo
102
12
Beds..
The LCD3 doesn't show battery bars,and road speed whereas a much smaller unit,kd21c unit does but has limited parameters therefore I'd like to use a more advanced one.
It is compatible. It won't show speed unless you have a speed sensor connected to the controller and you set P2 to the correct value. The battery display can get mixed up between 48v and 36v. You have to make it clear what battery you have. If you connect a fully charged 36v one, it can see it as an empty 48v one. You must first connect the battery in an unambiguous state of charge.
On the other hand, it's possible that you've wiped out the display by incorrect connection. If you just push the connectors together without lining up the pins, the wrong pins can still make contact, which can damage the LCD. It'll still have basic display functions.
Any KT LCD will work with any KT controller, but there are sometimes software differences that mean that you don't have access to some parameters or settings.
8,212
The very latest lcd3 versions have many parameters, speed, odo, disatance/milage, temp & watts etc,etc.
