Hi all at Pedelecs Forum,
I am a 20 year time served Electronics/Electrical technician, so you can talk technical to me - however I am very new to eBikes & eBike kits!
I recently brought an eBike conversion kit - one of these Chinese 'off the shelf' kits for a unique/novelty bike project I'm currently doing, the kit consisted of a 36V brushless hub motor with Hall Sensors, 36v Black controller, LCD display & other associated parts, pas/brake sensors etc
Basically I didn't like the big bulky LCD display unit that was supplied with the kit so I checked the connection & ordered a smaller 880 display unit (See picture below) to replace it, unfortunately it does not work - it powers up, but thats about it. What I found is the connector, number of wires & wire colours are identical between the two display units, however the pin-outs are different. Basically I'm trying to find out if this 880 display is compatible with my controller? if so is it just a case of swapping wires around in the connector?, or have I brought a display unit which is simply not compatible with my kit?
If anyone needs further information - photos of supplied LCD unit or controller etc I can get this
Thanks in advance
Jamie
Thanks in advance
Jamie
