Does anybody know the proper name for this please?
aardvark5
267
84
65
ST3 Blurton
I know it is a Julet Cable End Plug but searching for that finds nothing.
Sometimes I take my computer/LED off and close the connection with this plug and I can continue cycling with pedal assist and throttle on full.
I want to buy a spare but don't know what the proper name is.
35722
richtea99
434
283
Not quite sure what the cap does - are the two pins connected together, or is it just a waterproof cover?
Yours looks like the 2 pins aren't aligned perpendicular to the 'key'/indentation in the green plastic, like most 2-pin connectors would be. Or are there more pins in there? Maybe a photo straight down the barrel might help identify it.
8,225
The Green Julet is 5 pin used for lcd display.
I'v not seen the julet version before it shorts four of the five wires in the lcd connector in to twp pairs so allows the pas and throttle to work without the lcd.
The wire short connectors are sometimes supplied with the controller, they aren't a standard item to buy on their own.
Pin 1/Red & Pin 2 /Blue are shorted and Pin 3 /Black & Pin 5 Yellow are shorted.
You could buy the male with a tale , bare the wires join them and heat shrink the wire end to make you own.
Reactions: Wirdy and aardvark5
