E Bike Hub Motor
newmanoid979
28
Good day
Would anybody be able to identify my e Bike hub motor and manufacturer as i am looking to rebuild it after a miss - hap i am trying to find a suitable Hall Sensor PCB board with sensors the original had 3 Hall sensors and a red speed sensor
It was from a company called Hongzer ( Amazon )-019
It is 36 volt 250 watt
the numbers on the hub are 36-FF-GAF
the serial numbers are 093726
the Hall PCB board is numbered 00-18
i have attached a few photos and would be grateful for anyKind regards
Bill assistance
3,917
I can't recognise the motor. It's just a standard Chinese geared motor, so nothing special about it. This looks similar to your PCB:
You don't need a PCB. You can get just the hall sensors and glue them into the motor, then wire them to the motor cable. hall sensors are SS41 or you can solder them into your existing PCB, or use any way you want to connect them to the wires. The pcb is just a holder for them:
