I purchased a custom built e-bike 2 years ago from someone (I can no longer get in touch with them though) and it's been fairly reliable. Recently however, it has stopped assisting when I pedal. It happened during a cycle journey and it was working fine and then just suddenly stopped while I was midway up a hill. The battery had plenty of charge and the motor is fine as well because I can use the thumb throttle which makes it work. Managed to get home and put the bike on a workstand. Using my hands, I get no power assistance at all when I pedal but it gives power on the throttle.
I don't fully understand how the pedal sensor works but it seems intact and without damage (picture of it is attached). I opened up the little bag housing the controller (picture also attached). There's a bunch of wires none of which I know what they do, but the ones that were connected, I checked to make sure they were pushed in okay. There doesn't appear to be any loose wires that have come undone. The few loose wires have hot glue over the connector in a way to cap them off as they are unused (so I know they were not connected).
Can anyone help me work out how to diagnose this issue and figure out how to replace the pedal sensor if that is what is wrong?
Thanks in advance
Thanks in advance
