Help! E07 error on dual mode controller
mekanicu
May 21, 2025
România
Hello! I have a Prophete Graveler 48V with rebranded bafang motor (Called AEG but battery and mid drive is made by bafang)
Its original controller suffered water damage and because there doesn't exist a replacement and the battery gives power without CAN handshake, i took the opportunity and installed a "brainpower" controller, with its original dash S886,later replaced with a G51 (similar to S866) and a 12 magnet PAS sensor
The motor is 250W Hall-less and the controller works fine with it but both dashes say the E-07 ERR (hall error), S866 showed odo but G51 doesn't do it, both comunicate with the controller, both show the speed but i cant get around the error, The motor is similar to the bafang M4XX one but except it doesnt have the hall sensors holes so i cant add them.
I let it self Study, (2 green wires), but it still doesnt want to ignore the E07, its sad because of them the "Power " section remains empty, and Odometer doesnt work because its in a error state.
3,858
Have a look to see if you can change P20. If you can, try whatever settings are there to see if any others work.
