E42 on carrero vulca
Okkchris666
Jun 30, 2020
I have rewired the motor from controller direct to motor pcb and tested the hall sensors and phase wires all test ok but still getting E42 ...Any ideas ?
3,986
Logically, it must be a fault inside the controller, like a bad solder joint, wire pulled off or short. I think the controller is potted, so not easy to test.
8,226
Does the hall wiring check out continuity wise from motor to controller ?
