I have a bike with an electrical fault that I am having trouble fixing.
The bike is a rotation sensor electric bike. The bike runs okay but it has developed a tendency to cut out usually after going over a bump in the road. it will re-engaged after about 3 to 4 seconds or I have to go over another bump to get it going.
Clearly a wire is faulty but I can not seem to locate it.
Below are a list of things I have tried and each time the bike has been tested the problem has remained.
The throttle has always been disconnected.
1. Removed and cleaned magnetic sensor disc.
2. Replaced pedelec sensor cable.
3. Replaced control panel cable.
4. Disengaged brake sensor cables (remained disengaged)
5. Tested new cable connecting controller to motor.
6. Replaced controller.
7. New control panel and cable.
8. Swapped over magnetic sensor discs with one on another bike which worked fine. Also tested the one originally on the bike and it too worked fine.
9. Used different batteries.
10. Checked cable connections.
Is there a meter I can use to test current is passing through a cable and if so what should I look for?
