Hi yes came together and the screen works perfect sorry I meant the 3 led lights on hall sensor tester
If the wheel rotates when you operate the walk assist, there is nothing wrong with the controller, motor or battery. That leaves settings in the LCD, or connection issues (PAS and throttle) - possibly wrong connectors (swapped over).
The photo shows a connector with brown, yellow and black wires (colours for PAS) attached to the red white and black wires (throttle), and the brown is shown as shorted to black. You really need to sort out that mess.
Whenever testing a new system you should connect and test one thing at a time. Start with motor, controller and LCD connected. Test that the walk assist works. Next, connect the throttle and get it working, then the speed sensor, then the PAS, then the brakes, then anything else.
