I've seen one error code lots of times before -03- if I try and use the throttle when the bike isn't moving, however my controller kept resetting itself on the way home last night and throwing up lots of 03 errors when I was moving fairly quickly, turning the battery off an on again seemed to make the problem go away for a while (it didn't happen at all this morning). It seemed to make no difference if the road was bumpy or steep and the time between failures varied from instant to several minutes, it once went from an 03 error straight into an 02 error and back to 03. When I pressed the button on the battery I got four green lights, the fuse holder had caused a problem in the past but was glued into place by the Wisper service centre, though that problem seemed quite different when it was happening.
I'd like to able to narrow down the cause of these, can we know what the errors refer to?
