Testing the Q bike on a 1 in 3.3 hill section on motor only until near stall point, suddenly a huge grinding crash from the rear motor wheel and then it locked, at the very least the motor totally wrecked one might think.
Bounced the bike on the ground a couple of times until the drive returned and set off again. A bit further on it happened again, same cure, then from the top of the hill, a gentle minimum throttle ride home.
So did I strip the hub to see the damage? No, I just checked the Hall sensor lead and unplugged it at it's five pin connector under the bottom bracket, used contact cleaner on it, replugged it and re-insulated it.
So what was the horrendous noise? These very powerful hub motors have such strong magnetic forces that they are completely dependent on the pole magnetic fields keeping in perfect balance. The loss of one sensor connection threw the fast spinning rotor with it's heavy magnets so far out of balance that it struck the stationary stator with considerable force, the noise of the impact amplified by the alloy hub shell.
So if this happens to your very expensive e-bike, turn white by all means, but don't chuck yourself off the nearest bridge, just check and re-plug the connections of the five sensor wires and three power wires from the hub.
Some while ago there was a discussion about adding a plug in connector on the Torq, and at the time I advised against it, saying that soldered connections were better for just this reason. If my Q bike connector plays up again, I'll be taking my own advice and solder in place of the connector. No matter how good a plug, eventually they can lose a connection and perhaps strand you if you're not sure what's happened.
