Ezee Controller
wehey
117
7
52
Hi all.
I have just bought a new controller for my Ezee conversion kit as the old one was playing up.
Does anyone know what these connectors are for?
The old controller has just one of them (which is unused) and the new one has two.
Just wondering?
C
Cyclezee
That is a controller for post 2012 eZee bike, not for the conversion kit.
The connectors you circled are to power 36v front and rear lights.
If your eZee kit has the same type of connectors as the controller it will be fine but you might need to change the bullet connectors for Andersons.
wehey
117
7
52
Thanks for the reply.
It does appear to have the same connectors so hopefully it will work ok.
Will I have to set it up to run a 48v battery?
The old one is working intermittently. Sometimes it won’t work and the LED flashes 12 times and a few mins later it connects and it fine until you switch it off and on again.
I think some water has got into it after I got caught in a downpour ☹
C
Cyclezee
As far as running from a 48v battery is concerned that won't be a problem it will work perfectly well, but if you are using the post 2012 eZee LED display you will have to make sure that the correct voltage is selected.
wehey
117
7
52
I’m pretty sure I bought it off you in 2014 so hopefully I should be ok.
Do you remember how to select the 48v option? I’m sure I have an email somewhere on how to do it but I can’t seem to find it,
C
Cyclezee
Hold the ‘Up▲’ and ‘Down▼’ button together during power up to enter setup
menu.
Use Up▲ or Down▼ button to select the appropriate settings.
In menu setup, hold the ‘Down▼’ button for about 3 seconds to save and switch
to the next menu
Menu 1: Voltage Selection
1 – 36V (Default)
2 – 48V
Reactions: wehey
wehey
117
7
52
menu.
to the next menu
1 – 36V (Default)
2 – 48V
Thanks mate. All up and running again
