I've got an intermittent fault, which has slowly got worse. LED flashes 6 then 2. Often fixes itself after 10 minutes then stops again a few minutes later.
I've got two other Ezee bikes with interchangeable batteries so I know the battery is fine.
I've checked the wiring can't see any problems. I opened the controller, all looks nice and dry. I finally opened the motor, hoping to find an obvious loose wire, but nothing obvious. See photo. Any ideas?
