Hello pedelec hive mind, I'm hoping you can help me troubleshoot an old Ezee Torq bike I've got. I rode home last week and the bike was fine. Put it on charge. Next time I went to take it out the following occurs:
What I've tried:
Any ideas on what the fault might be?
- Turn on the bike. Red LED comes on and stays solid.
- Battery meter does it's LED dance as usual showing the initialisation process.
- After 5 seconds the meter shows this odd LED combo.
- Press the arrows a few times, the blue LEDs don't respond, however if you twist the throttle or pedal the bike the motor will kick in and the blue LEDs show up suddenly.
- Then after about 5 seconds the motor cuts out the the LEDs return to this display. Rinse and repeat.
What I've tried:
- Fully charged battery. Multimeter shows it on 41v.
- The red LED on the PCB where the key is stays on solid red the whole time, even when the motor cuts out at the battery gauge goes weird.
- Checked the fuse connectors inside the battery and they are solid.
- Checked, cleaned and reconnected several other connectors through the wiring.
- Tried the old wiggle various wires while powered up to see if it was a loose connection anywhere but nothing made a difference.
