Fat lad in need of ebike advice
paolocee
21
I'm 56, 6'4" and 150kgs (about 24st). Been unable to exercise for almost a decade after a serious accident. And the pounds have piled on. Finally got my new knee last month and want to get a bike. My kids and wife go on long, 40km rides, (we live in the middle of nowhere in Sweden) and I want to join them. But I know I'm far too unfit to keep up without cheating (and it's very hilly).
So I need an ebike, I guess. I'll be riding mostly on tarmac but also gravel paths and snow. Budget is £4k-£5k.
Your suggestions would be most welcome. It's a confusing buyers' market, especially for a monster like me!
I have seen the Haibike sDuro 3.0 mentioned in another thread but I can't find its weight limit anywhere.
Ta.
Crossroads
89
49
Riese & Muller GH variants are certified to 160KG, otherwise you are looking at Dutch Cargo Bikes and similar - Gazelle make a few - built like a tank and cheaper than R & M GH
Pump your tyres up to max, whatever you get,
paolocee
21
Thanks georgegenry. I did search before I started this thread and I saw that thread but it was inconclusive.
He seemed to go for the Haibike sDuro FullSeven 3.0 but I've looked and can't find any weight limits details that would support the claim that it could accommodate someone of my (or his) weight.
The only bike I've found that WILL support my big arse is the Riese & Muller GH Charger which is eye-wateringly expensive.
Reactions: Torque
paolocee
21
Sadly, the Charger GH has a rider limit of 135kg. So Riese & Muller are out.
paolocee
21
paolocee
21
BTW, I'm actually riding a normal bike at the moment. A Serious mountain bike. But only around my village as it's not happy with my weight!
Crossroads
89
49
Paolocee,
You make a good point, the frames of 'normal' good quality bikes will bear your weight and probably not be the main problem, but the wheels will be for certain and you would eventually suffer buckled wheels and broken spokes and any suspension would take a hammering and would need replacing a lot earlier. Please also note that the thread quoted above was for a 300 lb rider not a 350 KG rider (300 v 771 pounds)
My view is that a purpose built bike for heavy loads is going to cost more than your intended budget, but will be considerably cheaper than buying an unsuitable bike then buying a suitable bike later.
paolocee
21
Paolocee,
Ha, noted, but I'm 150kg, not 350kg (is that even possible?). I've nosed around more and found a German company who do electric bikes up to 170kg weight limit. Kalkhoff. Still not sure that's QUITE enough.
georgehenry
1,435
1,259
Surrey
I am over the weight limits myself and carry two full ortleib panniers on a rear rack on my Haibike sDuro 2015 Yamaha, and my 12/14 mile off road route to work has some challenging proper mountain bike sections for both me and the bike.
I like the simplicity of a hard tail and thought that I could simply add a stronger rear wheel. This is easy to do on a crank drive and not that expensive and has given me great reliability for many miles.
Although my own all up weight with panniers is around 120kg.
The advantage is that you can buy an entry level Cube or Haibike hardtail for around £1700 and then put in a nuclear strength rear wheel for around a couple of hundred quid and in all likelihood have no issues at all.
The frame on my Haibike appears to be overbuilt and a thing of beauty that has taken all the punishment I can throw at it in over 11,000 miles.
Reactions: paolocee
6,314
you will need thru axles front and back, top left in the pic, waight will not be a problem frame wise but the wheels might need upgrading from a stock cube hard tail.
31683
Reactions: paolocee
2,673
There were reliability issues with some Kalkhoff bikes; search around the forums here for more details. It may well be that those issues are now resolved; probably if you post details of a specific bike here somebody should be able to give more accurate information.
Reactions: paolocee
6,314
Reactions: paolocee
paolocee
21
From Steve at the Ebike Store:
“That is quite an old sheet but in reality, the bikes are tested for double the weight they get certified for. None are truly made specifically for the extra weight as far as I know but I am confident the one we have chosen would do the trick.”
