fitting new batterry mount plate cyclamatic p plus
rjosephb
9
hi all,
i have just received a new battery for my cyclamatic power plus.
it comes with...
1. new mounting bracket.
2. new connector pin block.
so i have to fit these before i can put the new battery in place.
the bottom of the existing mounting bracket has 4 screws and nyloc nuts; and two plastic side panels have to be removed to access and hold the nuts for unscrewing.
the non chain side panel comes off ok but on the chain side one of the panel screws is obscured by the crank arm/large chain cog.
could anyone please advise if i am correct in saying that the crank arm has to be removed in order to progress further.
are crank arm extractors standard size??
any recommendations!!
appreciated.
thanks
rj
rjosephb
9
hi all,
it comes with...
appreciated.
thanks
rj
the crank itself is the square type.
rj
anon4
574
90
33
GB
KirstinS
3,224
899
Brighton
Pictures speak in thousand words in cases such as this! Throw them at us [emoji3]
rjosephb
9
anon4.
the slide assembly is different to the original.
thanks for the links.
kirstin s
i do not own a camera.
rj
wheeliepete
2,047
757
Devon
You should be able to acess all the nuts from the non drive side, just cafefully remove the controller and wiring if it makes the job easier.
