Freego Hawk crossbar
Andy1865
289
15
Looking to upgrade the 250watt hub to a 500watt hub but need to squeeze the back forks to 135mm space. Can this be done safely? Thank you for looking
gray198
1,578
1,069
may be worth ringing Freego . I'm sure they will advise you on that. Marcin has always been very helpful.
jwm
139
41
Hampshire
The frame is metal, so it bends. Lever it, use nuts on threaded bar etc, heat it or whatever else. Take your time and it will be fine. Any manaufacturer is likely to say they "don't suport it", bla, blah as you'd expect. Have a search there are plenty of examples on the forum.
John
30,375
The rear frame on bikes with full size wheels can safely be stretched by 25 mm or so. I even do that to change tubes or tyres without taking a wheel out:
Andy1865
289
15
The rear wheel space is 17cm and has to pulled in to fit the Cyclotricity wheel.
30,375
Pulling in is less risky since no risk of breaking frame joint welds, but 35 mm is rather a lot and could leave the dropouts not at a right angle to the spindle. Ideally pull in a bit and add a couple of spacers, one each side or wherever best to centralise the wheel.
Andy1865
289
15
By all accounts the company thats doing the job says its ok i hope, and will add a Torque Arm as always fitted by them, but thank you for pointing that out to me. I'll email them the point uve put to me and see what they say to it
chris_n
656
399
Niedeau, Austria
What do you mean by "standard dimension" Chris
The frame measurement now / as manufactured / standard issue.
I see you have posted it is 170, if this is an aluminium frame no it is not safe! As Flecc says the dropouts won't be parallel. You are putting massive stresses into the chainstays. Unless the company doing the jop is going to properly stress relieve and heat treat the frame.
wheeliepete
2,047
755
Devon
It's a shame you did not ask for more advise here before you went ahead with this "upgrade". Fitting a large, heavy DD hub motor to your bike is not going to improve it, apart from removing the speed restriction. Fitting a 20 amp controller and LCD3 to your existing motor, as I suggested would.
Andy1865
289
15
I havant gone ahead with it yet and im taking this all onboard, but thank you for the advice.
Andy1865
289
15
How much is a 20amp controller and a LCD3 please. Would this be compatible with the current motor.
wheeliepete
2,047
755
Devon
See the links in post #5, that controller will fit into your existing housing and run sweet with your existing motor, but will prob. need some soldering/wiring. Please don't think I am trying to ruin your plans, but I can't help getting a bit "shouty" when I see someone taking a wrong turn.:)
Andy1865
289
15
Im a complete novice when it comes to wiring/ soldering. I completly understand you Pete and thank you
Andy1865
289
15
Good evening, does anybody know what the Amp is on the controller of a Cyclotricity 250/500watt rear wheel kit. Thank you
