Geometry question
Mike63
809
64
Hi...I need to find the diameter of my handlebars,
If I determine the circumference, using a piece of wire, can I find the diameter from this measurement ?
....cheers....Mike
trex
7,703
2,671
yes, you divide the circumference by the number PI ( 3.14).
Alan Quay
2,351
1,076
Devon
...and the answer will be 22mm, unless you need to know the clamp size.
Sent from my HTC 10 using Tapatalk
Mike63
809
64
Thanks trex...thanks Alan.
...Yes it's the clamp size I need....I'll sort it tomorrow.
cheers....Mike
All handlebars except some Bromptoms are 22mm at the grip end. In the middle, they're 25mm or 31.8mm. You don't need to measure them: It should be obvious which of the two they are.
Reactions: Mike63 and Gringo
Mike63
809
64
Thanks for that d8veh, nice to know...mine are quite obviously 31.8mm
....many thanks....Mike
