Giant revive
cwah
3,048
179
www.whatonlondon.co.uk
Wicky
2,823
4,011
Colchester, Essex
www.jhepburn.co.uk
Is that a lever of some kind under the seat or on the gate behind? edit looks like the seat is on a rail at the top of the square frame member.
Or can the shock length be increased to raise the seat height or put a cushion on the seat.
Reactions: cwah
cwah
3,048
179
According to the manual, the level below should allow seat adjustment:
https://www.manualslib.com/manual/60954/Giant-Revive.html?page=5#manual
But nothing happen. Looks like something is stuck. Probably rust or something similar. I don't know what to do
Fat Rat
1,903
726
UK
Carefully applied heat from a blowtorch on seized area taking care not to set fire to it!
Blow torch :(
If you need heat you want something like a paint stripper heat gun (no flames)
Still be careful but you can get a lot more controlled heat at the surface before damage occurs
Reactions: chris_n
cwah
3,048
179
cwah
3,048
179
Reactions: LeighPing and flecc
