Giant twist escape hybrid 1
J2k88
7
North Somerset
Hi I was recently given a giant escape hybrid 1 by my friend, it' in need of some tlc the battery doesn't hold much charge So is it worth replacing, as I've been told the ecu units on this type of bike can also be faulty? Any help would be appreciated thanks
J2k88
7
North Somerset
Yes everything works, the motor starts, just seems the battery doesn' deliver a full charge, I've found one battery and it' over 400 pounds
J2k88
7
North Somerset
The battery is on charge now the pack is on 3 bars, but the battery charger block is just flashing red, what does this mean?
horseunderwater
50
9
64
cb7 5qu
recelling the battery with upgraded cells is not very cheap either i was quoted 245 for the standard batteries (equivalent to whats in the case already) and 295 for upgraded cells which increase the range significantly
horseunderwater
50
9
64
cb7 5qu
is the battery on or off the bike im asking because i had a similar problem and found that after several trys the battery would charge but only on the bike
