going to fit my wattmeter but want too checkhere before i do
footpump
713
75
75
DSCF1652.JPG hi all
bought a wattmeter last year but did not fit it.
since then I have 2 more batteries, and have changed some of my battery /controller conections to xt60
I just want to check my connections in pic are correct.
the meter will be in the lower seat post tube area about 6-10" above bottom bracket. so will be difficult to see any readings output from meter.
what I am not sure about is if your stationary , does the meter display wattage/battery remaining charge.
I don't think I will leave meter on bike as a permanent fixture but interested in how my different batteries are performing.
can see the 12g wires on wattmeter being a faff to solder to xt60?
thanks all
5,785
14g wires are easier to solder and adequate up to around 30A.
Don't forget that it's conventional to have female connector on anything that's live, so you should have a female on the battery wire, a male on the battery side of the wattmeter and a female on the controller side.
The wattmeter will keep its data as long as it remains connected to a live source, but will start again if you switch off or disconnect the battery.
