Greenedge CS2 e-bike charger
RMBIKE
Jul 30, 2020
Hi, please help. I have had my Greenedge cs2 electric bike for a couple of years. I recently moved house and have misplaced the charger. The battery is a 36v 9AH bottle type. I have given up ever finding it and have been looking online but can not seem to find the charger. To be honest I don't even know if I'm looking in the right place (Ebay, Amazon etc). Does anyone know where I can find it please? I would be ever so grateful. Thanks and kind regards.
8,773
You can use any 36v generic charger as long as the charge connector is the same.
Reactions: Bikes4two
RMBIKE
Jul 30, 2020
Hi, thanks for the reply. Is there any way to work out what size charge connector goes in the battery? I see loads of 36v chargers on Ebay but none are 9ah, its usually higher. Would that matter for my batteries? Thanks again for replying.
8,773
It doesn't matter what the battery capacity is, a typical 2a charger will charge a 9ah battery in approx. 4.5hrs when empty. A 15ah battery would take 7.5hrs.
Show us a pic of your battery charge inlet so we can see what you need.
8,773
Don't buy this charger because it is quite expensive and you should be able to get one for half the price with the correct charge connector you need.
Open the link though and look at all the various charge connectors so you know which type you need and it's name to make looking for the correct item easier.
8,773
Ok that's a very common 5.5mm dc connector.
This the type you need, it is 2a so will charge your battery in 4.5hrs from empty.
It is for 36v nominal battery with a 42v max charge voltage.
8,773
