I have a 36v system built around a KT-LCD5 display, KT36SVPR-LCD controller and rear hub motor which doesn't seem to have any model number visible. All was working absolutely fine, except for one recent ride where the motor did cut out briefly and the 03 error code appeared, but disappeared after I powered off and back on. I did a ride in the south downs on Monday and everything was 100%, then on Tuesday started a ride - it started ok but after a few yards I got the Info 03 error code and no power from either throttle or PAS. Its been like that since then with no drive power at all. The display comes on ok, but the moment I use the throttle or PAS the error appears. What I've checked is:
Could it be the controller?
It's weird that the hall voltages didn't drop to 0V when spinning the wheel.
Another weird thing is that the battery BMS seems to have a problem - it won't charge. I've taken the shrink wrap off and checked all the obvious continuities and all are fine. I have a spare equivalent BMS so will probably fit that. But its weird that this appeared at the same time - I can't really see how they're linked, unless the controller shorted something...?? Its chucking out 42V so the power output is ok.
- visual check of all the connections and all look fine, no evidence of water ingress at all
- I've checked continuity across the 6 wire hall connector and all are ok.
- checked the voltage from ground to the yellow, blue, green and white Hall sensor wires - all were about 5.10V
- voltage across the red was 4.58V
- the voltage didn't change for any when I spun the wheel, so not dropping to 0V
- I DIDN'T check continuity to the Julet connector as I don't know the pin confuguration - not sure if the voltage check means this isn't necessary...?
