Headway 38120s 9ah 10c lifepo4
BAH48
166
15
Appleby Cumbria
Has anybody bought any of theses cells? BMS have them for about £7.25.
38120S 10C C-Rate 9Ah LiFePO4 Cylindrical Battery Cell with Screws Specification:
1. Normal Voltage:3.2Volts.
2. Dimension:diameter(mm) X High(mm) = 38±1mm X 122±1mm(132±1mm).
3. Capacity: 9Ah.
4. Maximal Charge Current: 5C(50Amps).
5. Maximal Continuous Discharge C-Rate: 10C(100Amps).
6. Maximal Discharge C-Rate: 15C(150Amps).
7. Overvoltage Protection: 3.65±0.05Volts.
8. Undervoltage Protection: 2.0Volts.
9. Lifecycle: 2000Cycles.
10. Weight: 330Grams.
11. Impedance: ≤10mΩ.
12. Chemical: LiFePO4.
muckymits
419
I have some 12 Ah but bought them in UK (Newcastle) to save the hassle of duty etc. The bike pulls like a train :D and not that much heavier than my LiPo.
jerrysimon
3,292
112
Cambridge, UK
Muckymits surely the Headways are MUCH heavier than lipos ?
They are also very big.
Regards
Jerry
muckymits
419
yes certainly bigger as you need the extra cell, will weigh them tomorrow as I cant find any of the scales, they must all be in the potting shed.
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
Regards
Jerry
Maybe his bike Weighs a ton anyway ;-) Jerry I'm going totake your title as lightest folder :p
I have this battery, which contains them:
36V10Ah LiFePO4 Battery 38120 Battery Pack with Carrier - BMSBATTERY
It's relatively heavy for its size as are all Headways. Using it with my GNG crank drive at 25amps, I get cut-outs after about 10 seconds of full throttle. No sign of significant sag on LEDs so It might be a BMS problem - temperature or current. I don't get cut-outs with lipos, so definitely the battery.
For the same weight, size and more or less the same money, I got a 20aH LiNiCoMn battery that can provide more current and go a lot further.
oigoi
467
7
3. Capacity: 9Ah.
I have the 10ah ones that I got from here:
eclipsebikes.com| bikes | electric bike kits | Pedal | Power
And they have been reliable and seem to have a decent capacity and long lifespan (lots of cycles) thought there are lighter battery options out there.
I also like the way it is easy to measure individual cell voltages and change one cell if it does go duff in the future
