Hi from sunny Hull
Ady1
10
Hi.
I have a 7 month old BH Atom Lynx 5.5 2019 that I purchased from 50 Cycles in Loughborough.
Unfortunately, they appear to have totally gone and my engine is broken.
I have had no support from BH in Spain and struggling to get anywhere.
It was suggested by 'Dewey' on 'the electric bike review forums' that I posted my problem on here too to see if anyone can help.
Regards
Adrian
Kwozzymodo
177
40
Lincolnshire
Ady1
10
Hi Kwozzy.
That site shows nothing for the UK.... or am I doing it wrong?
Wicky
2,823
4,011
Colchester, Essex
www.jhepburn.co.uk
Nearest dealer seems to be via Hull to Holland ferry.
50 Cycles are around but in a rejigged form following their bankrupcy - there's a thread on this forum where the company owner pops up and posts occasionally.
Scarily they claim to be still selling BH bikes.
Kwozzymodo
177
40
Lincolnshire
That’s what I mean - there isn’t a dealer in the UK. You might get somewhere by speaking to a European supplier. They may be able to help out with parts that you can get fitted locally.
Do you know what the issue is?
Kwozzymodo
177
40
Lincolnshire
50Cycles have mentioned something about becoming a B2B business, once they sort out their CVA
Ady1
10
Yeah, the nylon helical planetary gear has sheared.... same problem as the befang motors. Apparently this is a Dapu motor..... although it looks nothing like one!
Kwozzymodo
177
40
Lincolnshire
If you sent the dimensions of the gear to an ebike supplier that does motor parts, they may be able to help provide a replacement.
Ady1
10
Thankyou.
I may have it sorted, I will know in about 2 weeks :)
Ady1
10
Just to put this one to bed.....
All fixed now.
I found a retired engineer who machined a new gear (and a spare) and fitted it and put it all back together for £200 - all works perfect, albeit, the motor is a bit noisier.
Happy days....
Reactions: D C
8,224
The planet gears can be bought separately and usually held in place with a circlip, overall diameter, inner diameter, thickness and teeth count are required.
Nylon or steel are available if you search carefully.
