For Sale his and hers haibikes Sduro 7.0 and 5.0 2018 treking models
theloafer
24
64
durham
for sale as about due to upgrading would prefer to sell as a pair owning to the need for space regards new bikes arriving soon £3,400 ono just been serviced all updated and all diagnostics paperwork available .... also poss deliver for cost of fuel within reason ;)
his .. Sduro 7.0 returned to stock spec
  • Frame
    aluminium 6061, HD Interface, quick-release 5 x 135mm, disc brake Post Mount
  • Drive unit
    Bosch Performance CX, 250W, 75Nm, 25km/h
  • Display
    Bosch Intuvia
  • Battery
    Bosch PowerPack, 500 Wh
  • Charger
    Bosch quick charger 4A
  • Fork
    SR Suntour NCX-EB-DLO Lockout, steel spring, Travel: 63mm, steel steerer tube 1 1/8", quick release
  • Shifting system
    Shimano Deore XT M8000 Shadow Plus, 11 speed
  • Gear lever
    Shimano Deore XT M8000, rapidfire
  • Rear sprocket
    Shimano SLX M7000, 11-46 teeth
  • Chain
    Shimano HG601
  • Chain ring
    Miche, 16, steel
  • Brake lever
    Magura MT4
  • Front brake
    Magura MT4, 180mm, 2-piston disc brake
  • Rear brake
    Magura MT4, 160mm, 2-piston disc brake
  • Tyres
    Michelin Protek Cross, 42-622, 28" x 1.6"
  • Rims
    Rodi Black Rock 21, with eylets, hollow rim, aluminium
  • Front wheel hub
    Haibike Components TheHub ++
  • Rear wheel hub
  • Spokes
    Sapim Leader, black
  • Handlebar
    Haibike Components TheBar ++
  • Grips
    XLC Comfort bo3 with wrist rest
  • Stem
    Haibike Components TheStem ++, A-head, Bar bore: 31.8mm, 12˚
  • Head set
    A-Head Alloy 1 1/8", Cartridge
  • Saddle
    Selle Royal Viento
  • Seat post
    Haibike Components The seat post ++, patent, 31.6mm, aluminium
  • Pedals
    VP E461 mit Reflektor, aluminium
  • Head light
    Herrmans H-Black Pro E, 100 lux
  • Taillight
    AXA Blueline
  • Dynamo
    via system battery
  • Carrier
    system carrier, XLC Carrymore, max. 25kg
  • Mudguard
    SKS, chromoplastics
  • Kick stand
    Ursus Mooi, adjustable
  • Weight
    23.6kg
  • Total perm. weight
    130kg
  • Garmin and saddle not included
  • rear trunk bag with adapter plate
  • removes and installs in seconds
  • will be left on
hers ... Sduro 5.0 returned to stock spec
Frame
  • Drive unit
  • Display
    Bosch Intuvia
  • Battery
  • Charger
  • Fork
    SR Suntour NEX E25-LO Lockout, steel spring, Travel: 63mm, steel steerer tube 1 1/8", quick release
  • Shifting system
    Shimano Alivio M4000, 9 speed
  • Gear lever
    Shimano Alivio M4000, rapidfire
  • Rear sprocket
    SunRace CSM980, 11-40 teeth
  • Chain
    KMC X9
  • Chain ring
    Miche, 16, steel
  • Brake lever
    Shimano M315
  • Front brake
    Shimano M315, 180mm, 2-piston disc brake
  • Rear brake
    Shimano M315, 160mm, 2-piston disc brake
  • Tyres
  • Rims
  • Front wheel hub
  • Rear wheel hub
  • Spokes
    Sapim Leader, black
  • Handlebar
  • Grips
  • Stem
    Haibike Components TheStem +, A-head, Bar bore: 31.8mm, 7˚
  • Head set
    A-Head Tapered, ball bearing
  • Saddle
    Selle Royal Viento
  • Seat post
  • Pedals
  • Head light
    AXA Blueline, 30 lux
  • Taillight
    AXA Blueline
  • Dynamo
    via system battery
  • Carrier
  • Mudguard
    SKS, chromoplastics
  • Kick stand
  • Weight
    24.2kg
    130kg
  • Wheel size
    28"
squib
hi, I may be blind but i cant see what size frames these bikes are...
theloafer
24
64
durham
opps sorry about that .... my error
frames sizes 7.0 is small and 5.0 is xsmall but have found there run on the lager side I am 5-6 leg 30in and find it just a touch big..... the g/friends is 5-3 and that one fitted me much better
theloafer
24
64
durham
male 7.0 has sold
need the girlfriends gone drpped to £1,000
Frame
  • Drive unit
  • Display
    Bosch Intuvia
  • Battery
  • Charger
  • Fork
  • Shifting system
  • Gear lever
  • Rear sprocket
  • Chain
    KMC X9
  • Chain ring
    Miche, 16, steel
  • Brake lever
    Shimano M315
  • Front brake
  • Rear brake
  • Tyres
  • Rims
  • Front wheel hub
  • Rear wheel hub
  • Spokes
    Sapim Leader, black
  • Handlebar
  • Grips
  • Stem
  • Head set
  • Saddle
    Selle Royal Viento
  • Seat post
  • Pedals
  • Head light
  • Taillight
    AXA Blueline
  • Dynamo
    via system battery
  • Carrier
  • Mudguard
    SKS, chromoplastics
  • Kick stand
  • Weight
    24.2kg
    130kg
  • Wheel size
    28"
  • View attachment 29430
