Just curious on the views on this. I think I read somewhere around 6-10W power depending on hub motor but I can't seem to see that information now. I wonder if there is some formula for working this out.
I think its Grin technology who state that a combination of injecting such current plus combining it with regenerative braking actually results in a overall improvement in range and riding experience on their direct drive motors but then they are not exactly unbiased. I think they may have been the source of the 6-10W figure.
To me that is a surprisingly low figure, would the basic direct drive hub motors, ebay sourced etc have higher current demands for this.
If you wanted to create a switch for freewheeling based on a resistor in the cable that bypassed the normal throttle what would such a circuit look like and would you need any more protective components in that circuit diodes or capacitors? I assume the throttle is just a giant potentiometer.
I could measure the range of that potentiometer and the wattage used to give me a rough idea of resistor value for freewheeling?
Has anyone else done this before as a experiment. I realise higher end motors allow freewheeling as a parameter adjustment in the firmware/software of the controller but not for more basic
controllers without such options.
